289junkie
Newbie
- Aug 2, 2002
- 37
I'm in a pickle. And hope someone can give me an answer or direction.
I attempted to reassembly my front axle this afternoon. I have a 77 Dana 44 front with factory bronco disc brakes. I acquired a Power-Lok from a Jeep and switched the 19 spline to 30 using an internals kit (side gears, cross shaft, etc.). Soaked and installed new clutches as well as installed the new 4.10 gear set. Dropped everything in and reassembled the driver side without problems. Axle shaft, brakes and hub, all installed without issue.
But when I went to install the passenger side, the axle shaft is lacking approx 1/4" from being fully inserted. It feels like I"m hitting something. At first I assumed maybe a clutch spline interference. I chasing that rabbit for a bit, and didn't get any where. I decided to put from white grease on the end of the axle shaft and insert it to see if I can see what it is hitting.
After sliding the axle in, I can see white grease on the axle spacer pin located on the cross shafts. It's like the axleshaft is bit to long for use with a Power-Lok setup. Could that be the case?
Did I flip/mess something up when I rebuilt the Power-Lok? Do I need a shorter axle? Do I need the spacer pin?
I'm going to reevaluate in the daylight. I'm going to tear down the driver side and attempt to assemble the passenger side first. Why? I have no idea. I'm shooting in the dark here.
I'm afraid I'm going to open her back up. Any words of wisdom that may help me avoid taking 4 step back?
