Is There Anybody Out There That Makes A Small Block Or Spacer For The Front To Lift Up To Make Even With The Rear.i Have A New 3.5 Lift And The Back Sits Higher Than Front.about 1 Inch.
Yes, someone makes angled spacers that bolt on the spring cups, they are designed to make it so the cups are parallel to the frame on trucks that have been lifted quite a bit, so that the springs aren't bent. They lift the front end by about an inch. I think wildchild makes them but I'm not sure...Good luck! ;D
you could probably have a metal distributer cut some 5in diameter(whatever the spring plates are) an inch thick for real cheap,then just drill two holes in it. i wish i wouldve done that, i ended up returning 3.5s and got5.5s to get it to sit about an inch higher in the front. the 3.5 springs were so much softer and flexed more too. they were only in for about a year, but it still was rougher.
