Front Coil Spring lower pad help
70twocan
Enterprise
It looks like my front coil spring lower pads are bent. Do you guys have any ideas on the best set of heavy duty pads new or conversions. Thanks....
76stallion
Are you shure they are bent? they are specifically formed to moun on top of the radius arms. They kind of do look "bent", but that is the way they are supposed to be. Can you post a pic?
cesco
I bought a set a heavy duty coil cups from Cage, I guess maybe Bloody Knuckle Garage should have them now.
70twocan
70twocan
Enterprise
Yepper they are bent. I was thinking of putting just stock replacement ones on, but since I have it apart I'd like to put some "heavier" ones on....
Thanks for the responses keep um coming.
73stallion
Eugene, OR
i got some new replacement ones for mine and they have the same bend as the old ones. so i'm guessing the bend is factory.
mrw
MassHole
WildHorses has these in stainless for $30- That's some bling!
VT_Don
The photo link to the Duff front coil mount, has to be the most poorly designed product I recall seeing. No explaination needed.
bmc69
Why do you say that? Looks like a nice set of mounts to me...?:? In particular I like that they did a good job of eliminating the second clamping plate.
