dgamos1
The front driver turn signa lightl is not working but all other lights are. A The other three turn signal lights, all four flasher lights, including front driver side. All market lights, head lights, etc. Based on my wiring diagram, the column front left (driver's side) turn signal guess directly to front turn signal lights and then daisy chains from there to back to signal. If that's the case, how can the front not be working?? I already clean and confirmed all four signal light grounding points are good. I guess power may be separate for signal vs hazard. There's only two wires to turn signal light so I'm not sure how the blinking party of switch powers the larger bulb filaments, but I know it works when hazard switch is turned on. Any suggestions would be greatly appreciated!
David-
74 Bronco Sport, auto trans, power steering, WH front disc brakes, new 302 crate motor, Holley Sniper fuel injection.
David-
