Wyattman2015
- Oct 10, 2022
- 42
Hi,
Does anyone have details of front fender install ?
Robert
Robert
I stand corrected on removing the grill, it is not necessary. I did though remove my grill to do some other work in the radiator area.It's been a few years, but as I recall, you have to pull the grill off to get the fenders off. Lots of fun..anyway .
You left out the good stuff:Done this 20 times in past few weeks.
1. Unbolt grill from fender. Bolts are inside wheel well and one on top where grill and fender meet hood.
2. Remove fender braces at bottom of fenders.
3. No need to remove door! Open door to 90’ ( must remove door straps) and you will see 3 bolts at back of fender on the pillar.
4. Remove the bolts on fender edge in engine bay.
5. Carefully lift fender and with door open at 90’ pull front of fender away from grill and to about a 30’ angle from body and the rear of fender will come out from door gap.
Goes back the same way in reverse.
just experienced this last night!26. Install door seals. Throw a cuss tantrum as all that fitment work went out the window.
23. Connect to Internet. Determine EXACT location of Bronco emblem and decide whether to install "Sport" or Standard emblems. Tape and mark location of emblem holes to fender. Try to figure out how to hold an emblem with 6 pointy studs against a fender and mark holes. Apply never-sieze to tip of emblem pins and touch off on fender. Discover that anti-sieze was a terrible choice. Go back to workshop and create a template for the holes out of Wild Horses C-flute corrugated carton flap. Drill holes in template to match emblem. Attach template to fender. Drill holes in fender. Destroy template with drill chuck. Make a new template. Drill holes to size, countersink and finish. Test fit emblem. Break off emblem pin during test fitting.
Ok, since you referenced me without putting the "@" sign in front of my name, I didn't get notified. @Torkman66FYI, after going through all the steps above, at a place where everything is lined up very nice. 3/16” gaps front and rear doors. 1/4”rockers. Hood right at grill tip. I had to shave 1/16” off the front and rears off the doors. That is enough to break through the door skins in multiple places. No problem though. Just shave off a bit more than you want the gap to be then spot weld up the edge to close the skin back on the door. Then very carefully and slowly, with precision, grind down the weld to the gap you want. Takes about 90 minutes per door. Then with the future body work, gaps will be very nice.
I also unpackaged the new lower door seals from WH, removed the push in tabs, and taped the seal in place. No problem shutting door. I did have to slightly bend inward the seal mounting lip on the kick panels, but after that they closed fine. Tight, firm, but not hard to close.
As James points out, you can slap it together and it will be as good as the factory did it. Or you can put in the time, be patient, and get it looking very nice. But it takes many hours of tweeking, bending, welding, and going back over it several times.
Hi. Great working with you. Here's a pic of the last Bronco that I bought. Your secret is safe...LMAO!!! That is so hilarious. @jamesroney But lets be serious...if you bought this Bronco in the years ahead, within a week you would have a schematic that maps every line, every body measurement, analysis of what was stock and what was not, and would be asking the PO who did the incredible work on the doors. Then you would contact me and give me some grief about how it could have been done even better...I would then learn even more tricks of the trade from you and all would be good in the universe.
No, but if you ever need a body measurement, just let me know and I can pretty much make up any number that you want to hear.Is that the same Bronco in your post #6?
