jason.k
So the rear floor pan is done! Now moving to the front and ran into a potential problem or at least more work. The PO covered the rotted floor out by adding sheet metal over the top. I cut that metal out last night and looked at my new floor pan to replace it and it doesn't seem right. The new floor pan 90 degrees closes to the door side. It looks like the ones I'm cutting out were flat and spot welded to the lip of I think its the inner rocker panel. Am I off course here? Is the new floor pan not like the OEM? All advice is appreciated.
