1972 Ford Bronco 4X4 Custom
VIN # U15GLN68344
4,000 miles since frame off restoration
Charcoal Gray on Black interior
Automatic transmission
Clean and Clear California Title
Offered at $21,990
Early Ford Broncos have become more and more desirable over the past 5 years. And, it is hard to find a clean rust free body that is in good running order. This is a show quality restored Bronco. No expense was spared as over $50,000 was invested in this project. The restoration was completed in March of 2008. Now is a great time to buy this classic at a fraction of its cost to build…it will look great showing up to surf at the beach or taking down to Mexico for the weekend. It will go anywhere and makes a statement doing it!
This Bronco has NEVER been taken off-road since it’s restoration and is in showroom condition. You can show up at your local car show and certainly be proud.
The engine is a brand new 331 stroker motor built by Jim Grubbs Motorsports out of Valencia, CA. We have all the paperwork and dyno sheets showing the following output:
At 3400rpm 400lb-ft 283 hp 4500 415lb-ft 365 hp 5500 405lb-ft 425hp 5700 408.6lb-ft 443.hp
All parts on the motor are brand new:
ARF heads
750hp double-pumper carb
JBA ceramic headers
Custom exhaust
New 4core aluminum radiator
Heavy duty thermostat
All suspension components are brand new as well:
Custom shock hoops
Long travel
King 2.5 shocks
Engine cage
Long arm kit
New steering system
Custom bump stops
All new bushings
Drag link tie-rod end rear springs
New ball joints
The transmission is a C4 automatic rebuilt: new bands, clutches, bushings, seals, rings, gaskets, torque converter, rebuilt transfer case, new BRNG seal kit, Dana 44, 9-inch rear, and new transmission cooler.
The following items were also replaced/installed:
New flaming river steering column and tilt wheel
New steering shaft and new yoke
New t-shift twin stick
New power steering box
Dakota digital dash
Tuffy security glove box
New disc brake conversion
Steel brake lines
Hydroboost brake system
New 23 gallon fuel tank
New bumper-mounted extra gas tank
Hood springs
New fuel lines and fuel pump
5 new 33-1250 BFG mud terrains and 5 new wheels
6-point roll cage tied to the frame
New Cordeau seats front and rear with 3point seatbelts as well as 5point belts
Seats on sliders and tied to cage
Custom front and rear bumpers
Extensive attention to detail was spent on the bodywork as the frame was removed and custom fiberglass flares were added. The door openings were molded to the metal frame so there are no lines or screw holes. There is no rust and it is in concours condition.
We have tons of receipts documenting the entire build process.
If you have any questions, please do not hesitate to contact Paul at 714-668-0345 or me@paulkramer.com I can email over 40 photos.
VIN # U15GLN68344
Offered at $21,990
ARF heads
JBA ceramic headers
Custom exhaust
Custom shock hoops
Long travel
King 2.5 shocks
Engine cage
Long arm kit
New steering system
Custom bump stops
All new bushings
New ball joints
Dakota digital dash
Steel brake lines
Hood springs
![IMG_0001.jpg](http://web.mac.com/autokennel/iWeb/AutoKennel/1972%20Ford%20Bronco%204X4%20Custom%20_files/IMG_0001.jpg)
![IMG_0008.jpg](http://web.mac.com/autokennel/iWeb/AutoKennel/1972%20Ford%20Bronco%204X4%20Custom%20_files/IMG_0008.jpg)
![IMG_0027.jpg](http://web.mac.com/autokennel/iWeb/AutoKennel/1972%20Ford%20Bronco%204X4%20Custom%20_files/IMG_0027.jpg)
