For Sale: New BTF High Steer Arm kit for Solid Industries D60 Knuckles
These are only *sort of* Bronco related - I bought these thinking I could make them work, but I'm going for a fairly low ride height so I can't go to full high steer. You also need to be using D60's with Solid keyed knuckles. Maybe a few of you are building other trucks too though (or a tall EB with limited up travel!).
These are the 1 ton GM tie rod end versions, but could be drilled out for rod ends if desired. These are for keyed Solid Industries D60 knuckles and use springs. Also included are two stud kits for installation (you supply 4X standard grade 8 fasteners for the holes in the keyway).
These have been installed on an axle in my shop, but never had tie rods connected, and have never been used. They won't work on my EB, so they are up for sale. Only damage is some scratches on the studs from removal on a couple that were tight. This setup would cost you $330 + shipping from BTF (if it was in stock!).
Price: $275 Shipped & Paypalled
![](https://farm5.staticflickr.com/4343/36268321851_2241c040f1_c.jpg)
![](https://farm5.staticflickr.com/4379/36360298046_728c071706_c.jpg)
