guidoverduci
I’ve got a non-efi aftermarket 23 gal fuel tank. After filling it up, I noticed fuel dripping out out of a 5/16 line that’s all the way to the left on the tank. I still ended up driving hit home, but when I pulled in the driveway it was spewing out pretty bad. It was a leaky hose. I replaced, no more leak. The rubber line is about 6 inches, then attaches to a hard line. It runs up and around a few things eventually ending up into my air filter. So I’m guessing some sort of vent setup. I also have a carter electric fuel pump with this setup.
So, I just want to make sure this is correct. If I slightly overfill this tank, fuel vents out that line. When I pulled the bad line, fuel dribbled out a bit, but then stopped. I had a cap on it for about 10-15 minutes while I swapped in a new line. When I pulled the cap off to slide the new line on, fuel spewed out pretty quickly, as if the pressure built in a short amount of time. Does all this sound normal, could enough pressure build on a full tank to run fuel all the way to the air filter?? I doubt it, there are some big bends and wrap arounds till it gets to the filter, but someone smarter than me can chime in! Thanks!
