I have a full width D44 from a 78 Bronco and was going to narrow it to fit the stock width. I read articles on grinding the cast peice and cutting approximately 6" from the long end and welding back together. I want to put a high pinion in and before I cut this I thought I would ask opinions on full width versus stock width. Should I narrow it or put full width axles at both ends? What about wheel offset if running full width? I'm planning on 5 inch suspension lift and use it for trails and rocks as well as occasionally commuting on streets and highways in the Arizona area. Thanks for your opinins.
