garage art
77bronco_ed
77bronco_ed
Here is another piece in my garage I had made several years ago. Measures about 60" long x 18" high. Stays on all the time! My nite light!!
Nice... I seen a smaller one @ Jeff's Bronco graveyard.
Looks like you have plenty of wall space for just about anything.
77bronco_ed
77bronco_ed
I can't imagine a small 120v to 12v-16v transformer would be very expensive , should be small enough to hide easily behind or within the grill.
I am just going to try the small LED lights that are sold for decorating. (ie Christmas lights.) Only need 4, might double them up for the head lights. I will try them tonight. Fairly cheap way to go if it works. The wire will go behind the wall.
HoosierDaddy
I figured that , but thought I'd just throw that out there for anyone else looking into doing this.
I'd want to look into it some more before I started stacking dimmers and transformers , need to make sure the parts will live together happily , otherwise you might let the smoke out. :)
eaglenest66
Hey Ed, just have to let you know that I tried the LED bulbs (Christmas ones) and took them back. Problem for me it that the LED lighting is different looking. At least for the clear ones for the headlight bulbs, they turned out to be blue. So I opted to go back to the C7s for color. More traditional. You will definitely need the 1" hole for those for the headlights though.
As for wall space, never enough! tim
El Kabong
Driving stuff Henry built
It's a little too late & probably too bright, but if you wanted some 120v lamps, PAR56 lamps are 7" diameter. They look a lot like headlights & are available in 120v. They come in various wattages. They're used in stage lighting. If someone is ever doing a 4 lamp front end, the PAR46 lamps are 5-3/4". I suppose a dimmer could be wired in to adjust them to taste. It's worth shopping around, price varies a lot for these.
PAR56 120v 200w
shamu
Lucky as the day is long.
Sachse,Tx
Jami, when people ask me If I want parts I keep em ;D They can alway be put to good use
I have a piece of a roof if you want to fill that sun roof hole. You can have it no charge! Another thing you just left behind...
ps- We need to get that MI plate back to MI...
shoot me a PM about the plate.
77bronco_ed
77bronco_ed
I wish I seen this post before I ran out a couple of times. Yes, you are right I did not like the color and the LED's I tried were not bright enough. I tried the c6 (LED) bulb. I thought that if it was bright enough I could file up the plastic to fit since they are only a bit larger than the 1/2 hole.
I'll have to get a hold of some larger drill bits. My dad said he would like a few larger bits. Crap... ;)
77bronco_ed
77bronco_ed
PAR56 120v 200w
Hey those are nice... I still need to get the holes bigger, If something happens this may be a great option. As long as I could find them in a lower wattage. 200 is too much, Once up I would like to leave it on quite a bit...
77bronco_ed
77bronco_ed
I was looking through my parts and found a set of the small buckets. I am all set, just need the lighting.
I see they have some glass/tile hole saws that are not to expensive. I guess i will pick up the 1" and try it out.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
That's cool. I have a grill that I plan on doing up as garage art, too, so these are all good idea about the headlights.
While we are talking garage art, here is one the wife had made up. This is my second one. The first one turned into a pile of melted plastic when the garage burned down. Can't remember where she got it. But it was some catalog with personalizable clocks.
stupidboy
My wifes porn star.
Morrisdale Pa.
There is an auto body panel shop in town here that Has about 10" of the whole side of a short wheelbase f150 on the side of the building, and the lights work. Thats kinda cool and its mine and taskers favorite color, Yellow.:cool:
fallingdown
Here is a grill I picked up for $10. I sprayed it red, I am still working on hooking up the LED Christmas lights.
FYI for anybody thinking about doing this project. If you twist off the three "connectors" on the back of the headlight bulb you will end up with three small holes just the right size to mount a small Christmas light in each hole. This method is not terribly bright but it is better then paying a glass shop to drill a hole in the bulb for you.
Also notice the garage "couch" I made from an old Bronco back seat.
Good luck!!!
[/IMG]
77bronco_ed
77bronco_ed
Another grill saved ;)
After trying it, just not crazy about the LED brightness and color.
I have an old fiberglass grill that needs some work but would be perfect for hanging if someone is interested just PM me.
Mine is set I just need to re-drill/open holes for different lighting. Once finally complete I'll post up the last of the photos. Getting side tracked at the moment.
HoosierDaddy
PAR56 120v 200w
Hey , there ya go ! and a standard dimmer will dim those down too.
fallingdown
I know the LEDs don't put out very much light but the best part about them is that you can leave them on all the time and they don't use any power (relatively speaking) plus they have a half a million hour run time.
The lights that El Kabong posted cost about $10 a bulb and probably have a 20,000 hour run time. If you leave your grill on for any length of time that could get expensive.
