Gas Cap
BroncoBub
Anybody know of a gas cap the fits 75 Bronco that covers and hides the stock filler neck screws? Pictures sources?
Thanks, Bub
fluffybunny
Newbie
My quarters have bondo cracks around the screws so I got a $3 chrome plumbing flange, dremeled the inside hole larger, scuffed, primed/painted, and installed using 3M double back tape. Good thing I already had the primer, paint, and tape or I would have spent more than the cost of that gas cap.
El Kabong
Driving stuff Henry built
I run a couple of flip open 68 Dodge Charger gas caps. I had to dremel out the center of the mounting ring to fit over the stock Bronco neck. IIrc I had to redrill some of the holes in the mounting ring to use the stock Bronco screw locations. I think 69 & 70 caps look similar, but have the word "FUEL" on the cap.
I first used one of these off a junkyard Charger on a 64 Falcon back in the 70s. I got a kick when I realized that they'd also work on the Bronco. I like not having to worry about losing a gas cap.
68 style:
69-70 style:
Stock on the Charger they used a big splash ring around the cap, but I run the caps without that outer ring.
A Google search for "1968 Dodge Charger gas cap" brings up several sources.
