sdreaden
I am swapping out the carrier in my 9" rearend. This rearend was rebuilt with a spool a couple of years ago but not many miles on it. The tooth pattern on the ring gear is currently on the toe. So question is when setting the gears up in a new carrier, should I try correct the tooth pattern or match the pattern that has already developed on the Toe? What are the reprocussions of the current wear pattern if I change it now?
