Bronco69Sport
So I finally picked up a hood scoop that fits my propane setup. Its a Boss 429Hood scoop. I did some modifications to that for more air intake, and had to mount it backwards so my field of view was better at the hoodline. I also cut out all of the hood which lays under the scoop for cooling purposes. Plasma works WONDERS! I did leave the cross members on the hood (well one needed to be choped earlier for my puller fan). Propane is setup and running great. Mounted a 10 gallon tank in the back. I have the dual fuel so I still have my stock 12 gallons of gas as well. I am also in the process of getting ready for the PSC train to show up. It ordered the double ended full hydraulic ram system. I shaved a few inches off the front cross member and made it flat across with a piece of 1/4" flat stock tucked in and welded. It looks factory and will give me more room for upward ram travel. I did get the psc high steer arms as well.
