KyleQ
- Apr 24, 2008
- 5,480
Alright - I've decided on a set of 42" TSL SX's for my new tire setup and now onto the details. I picked up a set of H1 beadlocks for ~$30 a pop with the rubber run-flat.
First question - looking at the rubber run-flats, can I run them as is? I don't plan on ever airing down below 10PSI - it would save a lot of time not having to modify them...
Second question - back spacing. What are you guys running with one tons? SpareParts? I know you are rocking a similar tire size and H1's -
Third question - re-centering. I'm digging the pressed center idea, looks like the easiest to install and get it square/straight. A buddy installed them and he said it was as easy and cutting out the old center, quick grinding, drop in the new and weld it up.
Getting excited - looking for the best deals I can find and then I'm pulling the trigger.
Kyle
Kyle
