Heater box refurb
deltabronco
Anyone refurb their heater box? Not talking about just doing seals, but also repainting. What would work best to restore the finish?
duffymahoney
I drilled out all the rivets and had the metal powder coated, then used some truck bed liner on the fiberglass (or whatever it is). I then changed the rivets and nuts and bolts out to stainless.
Wasn't super bad, I also upgraded the fan size while I was doing it.
nickgp
Super simple job. Elbow grease, new seals and some flat or semi gloss black and you are good to go.
deltabronco
deltabronco
The paint was the main thing I was wondering about. Thanks for the info guys.
redwards69
Double Oak, TX
Outstanding results!
bsquared
Not quite as nice as Duffy's, but Rustoleum gloss black worked well for me. Easy job, just takes time. Cheers, B2
deltabronco
deltabronco
I see people mention using the fusion paint. The box is pretty rigid so I would think standard paint would work.. Right?
Gwunited2
I am in the process of rebuilding my heater box. Did you all use a spray adhesive to attach the foam insulation to the two diverter flaps (if that's what they are called)?
Also, be careful with the fiberglass housing. Mine cracked when removing the pop rivets. Had to do an epoxy repair. Looking good so far though. I'm also upgrading the motor and squirrel cage.
BroncoJimbo
Long-term owner
North GA
I did mine years ago and it still looks fine. But, on my son's CJ5 the fiberglass portion looked old and faded. We used spray on rubberized undercoating and it really cleaned it up nicely.
BluebroncoNC
Asheville, NC
Might want to replace the coil while you're at it, had mine all nice and put together, 4 months later sprung a leak. Had to tear it all apart again.
Gwunited2
Put it all back together this evening. Everything is new or refinished, new heater core too. I'm going to reinstall it and try it out this weekend.
Gwunited2
Nice job.
Quick question, are you starting with the heater and building the bronco around it?
Thanks. This bronco is not a restoration. I was just replacing the cowl because it was rusted out. While the cowl was off, I decided to rebuild the heater box. The old heater core was shot so it needed attention.
Now that the box is rebuilt I can put the cowl back on and then mount the windshield frame. This is just a hunting/fishing rig that I want to get roadworthy. It would be nice to have heat in the winter when driving around camp.
Maybe in a few years I will rebuild it. Of course I will need a second one to drive around while this one gets restored.
Gwunited2
DuffMahoney, in your third picture does it matter which tab the red wired connector and orange wired connector attach too? I disconnected mine and can't remember which one was attached where.
Thank you,
