Help me locatemy engine leak!
Ed74
San Diego, CA
I recently replaced my:
1. Fuel pump gasket
2. Oil pressure sending unit gasket
3. Oil pan gasket
However, I still have a leak located around my fuel pump and oil filter. I cannot find it for the life of me. All the gaskets I replaced are sealed. I have oil on my fuel filter and dripping from my fuel pump after driving (not at idle). I figure the increased oil pressure is causing a minor leak. I also re-tightened my oil filter. After closer inspection, I noticed a clean area at the base of my oil filter. I wonder if this is the site of the leak. Is there any other place I may have overlooked? I hope I do not have to replace my filter. If so, then I will have wasted $15.00 worth of oil again since I had to replace my oil pan gasket twice!
Thanks,
Ed
