High Amp Alternators on Ebay??
73stallion
Eugene, OR
alterstart, yes i've dealt with them. we bought a alternator for jones' bronco. we called them, told them our application, and they sen us an alternator. very nice people to deal with, they know their stuff.
have you talked to RRAAYY2 first?
hakstooy
Alexandria, VA
I too got an alternator from them, after swapping the serpentine pulley it came with it really was simply a bolt in, physically at least.
You need to mod the wiring a little because the regulator is built-in, but its fairly trivial, bc has a diagram I think and there is another extensive online write up of the procedure online somewhere.
edit-
(jeez, i typed that i got a muffler from them...man i need to get more sleep)
edge4
Gonzales, Texas
I have bought three alternators and one starter from them. Alterstart is a good company to deal with. I have been to their shop outside of Dallas. Good service. If there is any modification necessary they will explain it and usually include the hardware. Most are bolt in or close to it.
Edge
pooterpot
Lumberton, Texas
i got that exact alternator about 9 months ago. took forever to get it working right. i had to tighten the belt alot and it still squeels all the time. also according to autozone it only puts out 150 amps if you get it only go for the 150 amp because it will save you a little money and get the 1 wire. i got the 3 wire and now everyone says to get the 1 wire. ask ray he knows about the problems i had
edge4
Gonzales, Texas
Ray is the obvious expert in this area and may correct me on this, but my experience has been that most big amp alternators prefer serpentine belts or dual V belts at a minimum.
73stallion
Eugene, OR
i noticed 2 of my friend's rancheros last week had the belt squeal a little when they first started them. i'll see what happens when i put my 130 amp on, maybe tomorrow.
RT
Mine squeels also .Even worse when I fire up the driving lights , high beams , rock lights, electric fans,stereo , CB, shaver, GPS, map lights , Turn signals , heater fan , air pumps , etc.
Not that I use them all at once , but still . %)
I was thinking of getting a larger belt to wrap arount the alt , water pump , power steering pump and crank to be the second belt. My alt is mounted down low so I think the angles might work. But I may be wrong , it's happened before :p
Anyone here tried this yet ??
bmc69
I have bought HO 1-wire alternators and mini-starters from Alterstart and have been very happy with both..no complaints. I was very careful in how I wired in the 1-wires though, and did avoid some of the usual issues that 1-wire setups can cause, as has been fully described by Ray on this board several times. Seems that both Ray and Alterstart are good sources, depending on what you want to do...it's good to have choices. ;D
RRRAAAYYY2
Brantford, Ontario
You guys know I couldn't resist saying something on this thread, LOL.
First to the technical question posted by EDGE4: You are correct about the pulley/belt system. In OE applications, a single V belt was never used in an application where the alternator was over a 100amps. A 6 groove serpentine belt can transfer tons more power than a single v belt. Double v's will work, but are very tricky to get set up properly.
As for the alternator posted on Ebay, it is an adaption of the GM 12si. Which is nearly identical to the older 10si, with a revamped rectifier bridge. Not a bad alternator, but...
We prefer to use the modern cs130 alternators for one wire applications. Their charge rate is a lot better in the lower rpms, and the top as well, just not as important. They are also a little more efficient because they have avalanche diodes. These diodes also offer greater protection against voltage spikes if you have stereo equipment of MSD/Crane type ignitions. Their big selling factor is their output in the bottom end. The bearings are also bigger and both front and rear are sealed roller bearings.
As for mounting. The Ebay unit is more of a bolt in. They have modified the GM 2" mouniting spool to be the same as the 3" Ford spool. Our units still have the 2" mounting spool, so you have to use a 1" spacer or a few washers to make the difference. Not a big deal, but you need to know before hand.
They both have the same distance from top mount to bottom mount. This is slightly shorter than the Ford mounting distances. There is, 99 times out of 100, enough play in your brackets slot to overcome this. But we have had two customers need to file a little off the slot, to make it bigger.
As for what I have in stock. I have a standard CS130ACSE with a Ford mount that produces 70amps @ 2250 rotor rpm and 120amps max, board member cost $100.00US. I also have a Thunder Series Ford Mount in stock that produces 67amps @ 2250 rotor rpm and 152amps max, board member cost $140.00US. Plus shipping.
Both are 1 wire mounts. Meaning you hook one wire from the alternator's main output post to the positive terminal of the battery. Everything else is done inside the alternator. That one wire will have to be upgraded as well, likely a 4ga will work fine if your battery is still under your hood. I can supply the wire as well, cost about $10.00 depending on ends and length.
If you want you can email me at sva-sales@worldchat.com and I can attach a flyer describing the alternator.
It should also be noted that do to the size and method of construction of the rectifier bridge, no GM alternator is ideally suited for heavy mud applications. The Ford rectifier bridge on the 3g is just way more open than the GM. That doesn't mean GM's don't work in the mud, just means long term durability is not as good as Fords. But we all knew that already right. ;D ;D ;D
broncow72
Village Idiot
Spring,TX.
I just picked one up from another forum member. I think it's a 100 A unit. How do I identify between the different units? Or at least identify mine?
RRRAAAYYY2
Brantford, Ontario
Post a picture and I should be able to tell you what the unit is based on. As for outputs, it is much harder, and typically requires an amp clamp or test bench to tell.
If it is one of my CS130 series, I should be able to give you an idea. As the stator leads on the 120amp have two leads per phase, the Thunder or Lightning ones each have four leads per phase.
All of our HO alternators come with the most expensive hd labels I could buy. They last about two days. Really pissed about it. We have been trying different labels for about a year now. Finally about two weeks ago we found some good ones, out of the US or course. Now we are just working on artwork etc. They won't be coming off like the expensive ones we got now. These are half the price, a lot smaller and less flashy though. But I don't care as they work, and in the end that is all that matters.
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
Hey RRRAAAYYY222
Whats with the "high" turnon with your alternators?? You change the settings on your amp machines on me?? Mine turns on and puts out a lot more good stuff at lower RPM than you just bragged about.
WORKS MIGHTY FINE!!!! The only complaint I have is the insulated rebar sized cables you included with the goodies. You know it is a real pain to bend and shape things that are that big. LOL
Now if I could just figure out what is wrong with the starter.
TOFIC
RRRAAAYYY2
Brantford, Ontario
They charge below what is listed. But since those figures are around or a bit below actual idle, I did not include the others. Both turn on in the 1600 rotor rpm range, which means you may see them trying to start charging during the crank cycle. :)
I don't know what to say about your starter. Have you removed it and had it checked outside the vehicle? If not try that and I would kind of hope it fails. As it is a lot easier to fix than any of the other things that could be causing the problem. Give me a call at 1-888-214-7774.
