I have an NV4500 swap kit, and a 4R70w swap kit for sale $3k ea. 4R70w is a 98 Explorer trans with a $1300 rebuild with reciept and warranty, new converter, new Advance Adapter Dana 20 adapter (the better kit IMO that uses a new main shaft), modded crossmember, good used flexplate, new converter nuts $3000
NV4500 is super clean and shifts into all gears smoothly, comes with billit flywheel with bolt on weight to be 50 or 28 oz., modern diaphram clutch, new Advance Adapters bell housing adapter and Dana 20 adapter with AA crossmember. Trans is the correct dodge gas 4wd version for early bronco. $3000
photos and inspections for serious only please
San Jose Ca. Sorry no shipping unless you arrange it. I can deliver to local trucking companies at no charge. Jim 408-219-129one
