Highlander Black Ops LED Lights
snevey
Redding
Snevey's Offroad is proud to announce our newest LED Lights. The Highlander Black-Ops Edition. Designed for the most extreme uses the Highlander Black-Ops LED Lights feature the same technology as the most expensive lights but still at an unbeatable price. With Snevey's 2 year replacement warranty. You can rest assured you will be taken care of if your light fails. Each light comes with mounting hardware. And wire kit. Featuring: Lexan Lenses Thinner Cooling Fins 20% More Light Output with the newest CREE LEDs. Spot, Flood or Combo beam. These are available in 5 watt single row,3 watt dual row and 35 watt pods.
So hurry and get your orders in.
snevey
snevey
Redding
Highlander Black Ops LED Lights 35 Watt PODS
Get our new Highlander Black-Ops Led Light Pods right here only 159.99 pair shipped to your door. These bad boys are 35watt 5000 lumens each. They have a CREE chip and a Lexan lens. Come with a full replacement 2 year warranty on any manufacturer defect. They are available in spot or flood beam.
7 5W CREE LEDs
4.3''
Flood, Spot optional
Raw lumen: 5000 lm
9-32V
Aluminum casting
Clear Optics PC lens
Operation Temp: -40˚C-150˚C
IP 68
2 Year Warranty
snevey
snevey
Redding
Highlander Black-Ops LED Light Bars
Snevey’s OffRoad is proud to announce the Highlander BLACK-OPs Edition. Designed for the most extreme uses the Highlander Black-Ops LED Light Bars features the same technology as the most expensive lights but still at an unbeatable price. 2 year replacement warranty. Each light comes with mounting hardware. And wire kit. Featuring: Lexan Lenses Thinner Cooling Fins 20% More Light Output Riveted Housing CREE LEDs. Spot, Flood or Combo beam. All in this Murdered out lens.
•Operating Voltage: 12V DC
•Waterproof rate: IP 67
•3w high intensity individual CREE LEDs
•Black aluminum heat-sink housing
•6000K color temperature
•Black Interchangeable Lens
•Aluminum mounting brackets included
•Available in both spot and flood light beam patterns
•2 Year replacment warrarnty
DR12" •72W total operating power •Lumns 5775
DR20" •120W total operating power •Lumns 8800
DR30" •180W total operating power •Lumns 14,500
DR40" •240W total operating power •Lumns 19,250
DR50" •288W total operating power •Lumns 26,000
snevey
snevey
Redding
Highlander Black-Ops 7" Pods
Highlander Black-Ops 7" Only 199.99pair Shipped
. 2 Yr Warranty
. Power: 51W
. Voltage: 9-32V
. LEDs: 17pcs
. Black Housing
. Theoretical Lumens Output: 3100 lm
. Operating Lumens Output: 2200 lm
. Lights size: 202*160*86mm
. Beam: Flood beam, Pencil beam
.*Working life:*30000*hours
. Working temperature:*-40~85℃
. LED color temperature:*5000K, 6500K
. Dust and waterproof: IP68,IP6K9K, SAE J1455Services and transport:
Product Feature:
1. Extremely long service life of the 17pcs high power LEDs
2. Close range illumination with clear lens
3. Dust and waterproof: The hight power LED work light can in the rain or harsh environments.
4. Back of the housing has large cooling ribs for optimized heat dissipation
5. Reverse battery and over-voltage protection
6.The glass surface can't be exploded easily under heat and cold temperature (-40°-+85°)
7.*Material:*Aluminium die cast housing,*stainless steel bracket,With handle
