Hozr
Trying to dial in the last little issue in my TA 670 and I can't figure it out. Cold start, idle, warm up are all great. I was running a little lean so I upped the front jets which solved most of the issues as well as changing the pump cam. Acceleration and cruise are excellent but there is one litttttttle issue.
Under normal operation I have a decent ping in 4th and 5th from 1800-2000 rpm. If I accelerate from 1000 up to 5000 it's not there but if i cruise back down to 1900 it's back. Below 1800 and above 2000 it's gone. Of course 1900 is my highway cruise speed......
Anyways, here are all the variables:
SBF 347 stroker
RPM Air Gap Intake
Holley TA 670
Proform HEI Dizzy
Autolite 104 plugs
Ford Racing Wires
ZF 5 speed
TA Setup:
primary jets 70
secondary jets 72
blue cam in #2 hole
Yellow secondary spring
#35 squirter
8.5 power valve
initial timing is 10 vacuum advance to 32
idle vacuum 17
I know the advance seems low at 10 but it pings HORRIBLY across the range if I go any higher. It doesn't blow any smoke under acceleration.
Thoughts? THanks
SBF 347 stroker
RPM Air Gap Intake
Holley TA 670
Proform HEI Dizzy
Autolite 104 plugs
Ford Racing Wires
ZF 5 speed
TA Setup:
primary jets 70
secondary jets 72
blue cam in #2 hole
#35 squirter
8.5 power valve
idle vacuum 17
Thoughts? THanks
