First, feel free to redirect me if I'm in the wrong place. I am a fairly new member (been using the site for info up till now) but this is my first post. And, as you might imagine, its to ask for help. I bought a 77 Bronco about a month ago that is pretty much "restored" as a daily driver, not a show vehicle. In fact, I have been using it as a daily for about 2 weeks now. It has a 302 (sounds like it has a small cam when idling) with a Holley 4412-3 carburetor. It has a manual choke that I have not had to use yet since I live in the Tennessee area which is pretty warm climate. It has a 5 speed NV3550.
Getting to the point...I have always felt it runs rich from the general smell of fuel while its running and when I get out of the Bronco after my short commute to and from work, my clothes smell faintly "fuelish". But now I have had two different situations where I had to sit idling waiting in a long line in one instance and sitting through some long lights in another instance. Both times the idle seem to start dropping, then it would die. Both times it would not restart even through its seemed like it wanted to (a little bit of ignition/run) but wouldn't actually start. The longer I tried it would only turn over and not fire at all. In each of these situations there was a very evident fuel odor. Of course each time I also had the embarrassment of having to get help pushing the Bronco out of traffic and off to the side.
The first time, not knowing what else to do and suspecting it was flooded, I let it sit for a long while (over an hour) and then it started and I was able to drive it home with no issues. The second time it happened...same thing. Acted the same as before and wouldn't restart. This time, however, I got some starter fluid (took me about ten minutes from the time it died) and sprayed starter fluid in the carb. It had a little trouble starting but acted like it wanted to. Sprayed starter fluid again and it started up. I revved the engine high and steady for about 10 seconds and let it come back to idle. Seemed OK at that point and I was able to drive it home.
Has anyone else experienced this that knows what the problem is and how to fix it? As per the title of this post, I my sense is that its somehow loading up and flooding while idling. Or, maybe its always "loading up" but since I'm driving under torque its burning all the fuel. In any case, I can sure use some help. As a side note, it fires up and runs well each and every time I get in it. Also might be worth noting that I am (or has least have been) a Chevy guy all my life, but always wanted a Bronco. So, not only is this my first Bronco, its my first Ford. I do love it A LOT...so much fun to drive, except when it leaves me stranded.
Thanks in advance.
Thanks in advance.
