I cant post a pic for you cause I just pulled my motor out . I will tell you that I tried to use my stock linkage and it would not work right without making a longer rod to the throttle on the carb . After doing so I didnt like it at all , I felt it was unsafe .
I ended up calling Chuck up at BC Broncos and ordering a SS cable linkage like a few others with this set up have done . It works great and was simple to install . Its a lot safer and cleaner under the hood now .
Trust me on this , you wont be sorry if you do this . It simplified everything about the linkage and the carb . If you have to remove the carb again which is likely , you will understand right away ! ;D
