SpareParts
- Nov 13, 2004
- 5,592
I did the EFI conversion last spring, I used some parts that I had already had. Bottom line, I know the upper intake is from a speed density Crown Vic. The intake port was only 52mm? That's what my conversion measurement came up with at least. The lower is a 351 truck lower that I have ported and gasket matched to the stock 80's-90's intake gasket with a BC adapter. You can hear the exhaust change tone about 3000 rpm and kinda sounds constipated! I assume that it is caused by the restriction in the upper intake and small throttle body.
The short block is a 30 over, fully balanced and ARP'ed with 9.5:1 pistons. It has a custom ground cam that is 204/210 duration with 460/480 lift, 110 deg. lobe sep. The heads are 72' Torino heads the have been ported heavily and gasket matched to the 72' big intake gaskets. I never flowbenched them but I know the do flow well.
The intake set-up I'm planning on is the Edelbrock Performer "already have" with a ported Typhoon lower. I just don't know how big of throttle body and mass air meter/injectors I should run.
The motor is set up for and has great torque but dies on the upper end. Currently I'm currently running the 19lbs. injectors, stock mustang mass air with a A9P computer and 92' harness.
Sorry for so much info at once!
Thanks in advance,
David
Thanks in advance,
David
