Probally going with PPG Daytona Sunset Orange. Kind of a burnt orange color.
Painting the tub exterior, dash, doors (both sides), tailgate, fenders. grill, hood and windsheild frame. I guess I should have said that from the begining.
Are they selling you a gallon of unreduced paint for $600? In PPG that will make 2 gallons reduced. Is the paint code GM 633H? If so I just checked my paint line and in Spies solvent it comes out to my cost as $83.25 a sprayable quart and retail $117.44. That is $330 my cost a gallon or $469.60 retail. That is sprayable with the reducer already added. If my memory is correct PPG is mixed 1:1 as is Dupont. That tends to make poor coverage as opposed to a line like Spies which is 2:1. With Spies you can get coverage in 2 coats with that color and a drop coat for metallic control.
Using that color I would spray a light to medium grey sealer. You should be able to get away with under a gallon of sprayable base easy, even with PPG. I sprayed my Bronco a similar color and only used 2 quarts Of Spies waterbourne. My brother sprays PPG water and he says it doesn't cover any better than solvent.
What I'm trying to say is cheaper isn't always cheaper in the long run. If you can get a little more expensive product last twice as long it's actually cheaper.
Yeah, I'm going with 633H for the paint. The $600 was for an unreduced gallon. The main reason I'm using the PPG is that's what my buddy uses in the shop he works in. "We" will be doing the painting at his house because his garage is set up for painting. I'll be going all the grunt work (sanding and such) and he will be spraying it for me.
Do you have to have different equipment to spray the waterborn paint?
how much primer do you need to paint the body?
