- Jan 23, 2012
- 592
I will have my Toms Bronco Parts family roll cage installed in the next couple of weeks and I am wondering if there is a kit to mount the cage to the chassis or do I just need someone to fab it up?
http://extremecustomparts.com/i-593637-family-roll-cage-kit-66-77-bronco-6-point-12.html
I am getting a cage kit with seat racks. This way even if the cage separates from the tub and/or the frame I am still secured within the cage.
bickintone,
are you saying that the sheet metal in the tub will not separate from the cage when enough force is applied?
Ok, thanks for clairifying. Now is it better to mount the seats to the tub or to the rollcage having roll cage bars crossing the floor?
What's wrong with bushing tie-in's? It's the proper way to do it if done correctly. Unless you have a trail only rig, you can't directly tie your cage to your frame otherwise you render all your flexible body mounts entirely useless and will transfer all kinds of frame vibration right into the body and interior cabin. The most commonly accepted means of addressing this is to use bushings at the cage mount points. Now I've seen some ass backwards attempts at this (on this forum) where somebody used bushing at the frame side basically introducing a hinge (bad thing).Fab it up, Cages are all different, so there is no "one size fits all" kit. Just don't do the bushing/bolt thing I've seen a few times on different threads. Hard mount em is the safest set up IMO. Good luck
Here's a good universal bushing tie-in kit:
http://4xinnovations.com/p-RC1715.html
I think if I ever do it again I might mount the cage through the body mount bolts. That would tie everything together and still keep utilize the body mounts anti vibration benifits. It would be very easy to do in the back and middle but the front would be a challenge.
Greg
