How to remove rust from behind striker post?
Ed74
San Diego, CA
What is the cheapest and most efficient way to remove rust from behind the striker post? Can I use a harbor freight spot blaster, since I cannot get in the tight spot with a grinder or DA sander? If so, how do I remove all the media from within the tight space behind the striker support panel, where it attaches to the inner quarter panel? I can use a shop vac, however I am concerned that I will still have debris left over, which will prevent the adhesion of the primer I will spray. Also, should I try to seam seal back there?
E
Ed74
San Diego, CA
Sounds good. I will purchase the spot media blaster gun at harbor freight and perform what you said.
