OK guys here's what i got. 75 5.0L EFI with all new disc/disc set up hydrotech hydroboost and master cylinder all new hard lines and flex lines. new WH disc/disc P valve. all new wiring harness.
Here's my problem. I have bleed the brake system 4-5 times now with different methods and dont seem to have any air bubbles. Not running, the brake peddle is firm and holds pressure. Running the brake peddle goes down quickly and the brake pressure light comes on and goes off when the peddle returns to normal. The second and third pumps (running) the peddle seems firmer at normal foot pressure but if i push harder the brake pressure light comes on again and goes off with just a slight let off of foot pressure. I cant seem to get the peddle to feel the same with every use. after shutting it off the brake peddle goes to the floor for one pump and returns to firm after that? This is all being done on jack stands. the power steering seems to be fine there is no air bubbles visible in the PS pump fluid?
Also with the key on and not running i can pump the brake peddle and never get the brake pressure light to come on.
What is going on what i am i missing?
Ok Go!
Ok Go!
