TOFIC
I started your re-bleed procedure, but wanted to confirm something before I continue.
I disconnected the LP line from the PS pump and capped the PS pump connection. The other end of the line is still attached to the Hboost. I placed the hose in a jug and started the engine and let it idle. Nothing came out of the hose - is that OK?. I couldn't get anything to come out of the hose until I stepped on the brake pedal. Fluid flowed most when I had the pedal down. Once I let up it slowed to a trickle then stopped.
Just want to be sure this does not indicate a problem.
