Wanted to circle back to the topic of hydroboost pushrod drive angle.
I've heard indirectly that if the brake pedal pushrod wasn't directly inline with HB bore that seals would wear very quickly. @toddz69 said his discussions with Vanco were consistent with that.
@jamesroney had a thread on his bracket modification that ended up with roughly 5 - 7 degree of off angle push here
@ntsqd had commented that his FSB unit purchased from Vanco has an offset pin similar to as shown here.Crappy drawing below to show that I think an offset pin eliminates lateral load on HB bore, which seems to corroborate above, unless the application was trying to not change pedal ratio for some reason.
My Hydratech firewall mounted bracket has about 5 degrees of "side" angle to clear EFI as shown in pic
I modified a Bronco brake pedal to go from 6:1 to 5:1 by moving the pin down 0.47", which will result in about 5 degrees off axis push. Pressing with a pedal force of 20 lbs results in 2 lbs lateral, 150 lbs of pedal force results in 13 lbs lateral which seems to be in realm of non-concerning to me.
Would love to hear if anybody has a configuration with high miles and a drive angle of more than 5 degrees.
