I installed my hydroboost using the "eBay bracket" - only issue I have is the pushrod doesn't fit the brake switch. The only way I can make it fit is to force the switch on just enough that the brakes are always on. This is independent of the push rod position - the switch and the push rod ole just don't line up enough.
Should I grind down the flat part of the pushrod just enough so that it will fit - or am I doing/using something wrong.
