beyer05
What are you guys using for a push rod for the master cylinder from the hydroboost? Are you just cutting down the stock push rod from the stock MC?
Madgyver said:The rod should be part of the hydroboost unit. I know it is with the Astro hydroboost. I can't say the same for the Lincoln.
Here is a breakdown pic of the Astro unit.
Your missing both the push rod and the retainer. The retainer as Mad mentioned above is kind of like a star washer that will be the same size as the outer diameter above. You could probably yank one out of another unit at the local u-pull-it.beyer05 said:Well, I believe my Lincoln must be different. Here is what I have and ALL I have.
I was thinking about making my own push rod. Is there anything that I need to know?
Don't get too hung up on the type of booster. They are all almost identical with only some mounting differences. As far as the pushrod goes the only difference is going to be how long it is for a particular master cylinder. Otherwise I doubt there will be much difference. Below I have taken Mads picture and circled the two pieces on it that you are missing. The rod (top circled item) goes in first with the white washer piece to the inside. Then the star washer looking retainer goes in to hold the rod in it with the tongs to the outside. (It is probably slightly concave) The tongs grab the inside to keep it from coming back out. I would suggest at least using something there to keep the rod centered if you decide to make one because the washer isn't there just to hold it in but is also there to keep the rod in the right place. Otherwsie there is a chance it could fall down when you let off the brakes and no longer be centered. Depending upon the situation there is the potential it could lock the brakes up if that happened.beyer05 said:Well, I hooked it all up last night and 'garage tested it and it seemed to work. I just (temporarily) used a 4 1/2" bolt from the hydroboost end (pictured above) and the MC (stock for now). So, I guess my question above still stands, what would be the problem with just making a push rod to go from one to the other?
Also, does anyone have a good picture of the parts I am missing? I would like to se what they look like (in a Lincoln booster)?
beyer05 said:Ok, this is helping.
1. Does anyone have a better picture of the rod?
2. Where does the star washer mount to on the booster?
3. Does the MC pressure push the rod back into the booster?
Here is what I am thinking:
1. Take the old push rod cut to length.
2. Weld a washer to it on the end right by the 'cupped' part of the booster to simulate the white washer.
3. Make/find a washer to simulate the 'star' washer that will sit in the end of the booster to keep the rod centered but allow it to slide in and out.
They should be 9/16".beyer05 said:That would be great. The threads are 3/8". I guess a 5/8" or 11/16" wrench??
