ChiefDan
Ok, I managed to yet again burn up a starter solenoid while trying to fire my bronco up after replacing the carb.<br>Go to napa, get the heavy duty model, slap it on, now the mule won't start from the key switch. I can get it to turn over by applying 12V to the solenoid. <br>My question, does the igntition start position from the keyswtich run through the voltage regulator? Or should I pull the key switch out and look for a problem there.<br>Not very familiar with the wiring for the start position of the key switch, so any ideas are as always greatly appreciated.<br><br>Dan
