Injector Question
pcf_mark
I took my 5.0 HO intake apart to clean inspect. I removed the fuel rail with the injectors attached. On one of the injectors the small orange plastic base came off. This is the small plastic doohickey lower down on the injector than the o-ring.
Is this thing important? Where can I get one w/o buying another injector?
It does not look like it does anything but I do not know.
Thanks Fellas!
Steve83
The lip of the cap spaces the whole injector up from the intake so it stays in the fuel rail. Without it, eventually, the pressure & vibration will blow the injector down & cause a massive fuel dump on top of the hot, running engine.
Replace it, even if you have to buy an injector. They're only a few bucks at any JY.
pcf_mark
pcf_mark
Thank you for the "tip" (of the injector that is!)
That makes sense - it is part of the installed height so w/o it the injector could move out of position. I cant say enough how awesome this site is.
KyleQ
I got a nice rebuild kit from RJM, but Egay may be faster. To get the screen filters out of the top, screw in a wood screw a bit and yank them out, works like a charm.
