GubNi
I've been building a 77 Bronco from a frame and tub with mostly spare parts like full width axles and some wore out 35's. In general it's went pretty smooth other than complications from having a 5.0 engine instead of a 302. I have a newer fuel injected 5.0 motor that has the old carb intake on it and a NP435-205 from a 77 F-250. I used a bellhousing off a 68 Bronco. I bought a new flywheel and clutch kit for a 86 Bronco which should be right for the motor balancing and the starter teeth. When I put the 435 in I couldn't get it to go the last half inch. I put the bolts in and tightened them gently with a ratchet and they seemed to go ok. I went to start it tonight and it acted like the battery was low, so I hooked up the charger and set it to 200amp start. Still nothing. I put a socket on the crank and it won't turn over. I took out the starter and used a pry bar on the flywheel and it won't budge. I'm guessing the problem is with the transmission connecting to the motor. Any ideals?
