Installing 23 gallon tank - top of tank
76YETI
KC METRO
What is everyone using between the top of the tank and the bottom of the floor.
Weatherstripping?
Thanks.
tasker
all knowing of nothing
NH
no need on mine, there is a space between the both of them...
74BroncoCO
Are you talking about the little feet that keep the tank from contacting the body?
I had a piece of 1x4x@24" long pine in there next to the feet as I figured it would rub a hole in the tank or damage the body.
Jamie Chriss
Are you using the WH M1 tank? Your will need a few pieces of think rubber so the tank rests against the floor. I think this was mentioned in the post about the stainless steel tank?
blubuckaroo
Grease Monkey
Ridgefield WA
Tanks that use straps for mounting press the tank up against the floor. A sheet of rubber would be a good idea. Cut up an old inner tube. Nobody is going to see it for years.
hankjr
If you have a rear seat, make sure you have sufficient clearance between the seat belt and seat bolts and the fuel tank.
Hank
Bronco4x4
If you have a body lift you may need to add lift blocks with rubber to the tank tabs on top.
904Bronco
San Martin, CA
Like so...
Can also use some dense plastic glued to the metal feet...
.94 OR
I put the Tom's 23 gallon in mine last month. I used some high density foam sealing tape on mine since I had it and it appeared to be what I was looking for.
.94 OR
I'll probably take a lot of abuse for this, but I'll share a couple pics of mine.
I printed up some fuel line clamps to hold the pressure and return lines plus the air line for the rear locker and the rear brake hardline. It has a cradle on top to zip-tie the wire loom into as well (there is a heat shield to cover it, but off for the pics). Fuel filter mounts on the outside of the frame rail for easy access and minimal heat. Low pressure pump with pressure cutoffs to transfer fuel from side tank to rear tank if I need more capacity. I also printed an air cleaner spacer to get up over the return line out of the FiTech. Gauge on front allows pressure monitoring at the TB.
bronkenn
Bronco Guy
Southeast Ohio
That gauge on the fuel injection is one of the best things for troubleshooting problems. Have used it a few times when TB was acting up.
