intake manifold leak?
Broncology
What do I need to do to fix the leak. Is it fixed by a bead of silicon and/or gasket. Also, how difficult would this be for a novice? Is this something better left to the professionals? I am assuming a torque wrench would be needed, what else? Thanks in advance
68 Broncoholic
WA
Its not that bad. Drain the water down, take out all the manifold bolts and set the manifold a side with carb and linkages still attached. Clean both surfaces and I like to use some high temp silicone sealant on the head side of the gasket and then add some across the valley and a generous amount at the corners. Re-install the intake straight down, don't move it around otherwise the gasket can move on you. Use a few bolts to keep things inline.
I don't use a torque wrench on the intake. I'm sure its a nice option but never seemed to use it there. Don't crank them down, just snug.
kontinu
mount holly
I just went throught the worst intake manifold ordeal of my life (well the only one at that but it was still bad ;) ) I upgraded from a 2 barrel carb to a 4 barrel carb and new intake manfold. At first I used new gaskets and left out the cork gaskets that go in the front and rear and used a real heavy bead of silicone (saw it on horsepower tv) Well thats the last time I listen to them. It leaked out of the back of the intake manifold where I had left out the cork gasket and used only silicone. Took it apart. Had to buy new gaskets all together. Put that on with just a wrench, that leaked antifreeze. Took it apart and put a bead of silicone on the gasket then set it on the block and let it set up so it didn't move when the manifold was put back on. Tightened it down with a wrench and it leaked again. Took it apart and now put silicone around everything possible (both side of gasket and put it back together) I went and got my dads torque wrench and tightened it all up to 25lb in a criss cross manor middle to ends and vise versa. I went over them all about 3-4 times until they were all the same and didn't tighen any more. No problems. Learn from me! DO it right.
Duke Nukem
Simi Valley
I agree with kontinu that you should use a torque wrench. You can buy one at any hardware store and it is something that will come in handy more often than you think. There is a torque order in the chilton's manual that you should follow and the bolts get torqued to about 25 lbs. I've always just used a heavy bead of RTV in the front and back and have never had any problems.
COBlu77
Arvada, CO
Remember to re-torque the bolts after you've gotten it up to temp. I had to re-torque mine 3 times before they stopped loosening. I have done it both ways, with the cork at each end and with-out (1/4" bead of silicone) and it worked both ways just fine.
