Cam is in a 302 and is in good shape. Wear pattern is acceptable... I know that it is unadvised to use the same lifters on a new cam, but what about new lifters on a used cam (if it is still in shape)?
you can use old lifters but they need to stay on the same lobe they cam off . Using new lifters on a old cam is fine as well just lube up and break in like a new cam. I've done it several times and have yet to have a failure.
Awesome thank you for that. What are the break in protocol for an engine with new lifters? Just apply the engine assembly lube with Moly grease to each set on top, bottom and sides?
Make sure you use PLENTY of assembly lube and real break in oil (don't buy any crap in an auto parts store....get it from Comp Cams or some other cam grinder).
