Knuckle reamer F up Fix?
bax
Old Member
I was reaming out a dana 30 knuckle for a steering upgrade today and went way too deep. Should I just find another knuckle or is there a good way to fix what I have done? can I drill it out to a thick wall tubing size and weld the tubing into place and then ream it over again to the correct size? Any good ways to fix this?
Thanks Bax
bax
bax
Old Member
Thank you very much. That looks like a good way out of my mess.
NYLES
bax if it gets real bad you can have my 30 its in Crestview
bax
bax
Old Member
Thanks Nyles I have another 30 in the garage I just didn't want to take it apart. These little fix it bushings look wonderful.
NYLES
Yea look a like nice fix, and easy on the pocket.
deltarat
Drew,Ms
Do you weld them in or leave loose? I see they are split tapered, but it seems like they should be welded.
bax
bax
Old Member
With the shoulder on them I think they will work fine not welded. my worry was how soft they might be.
sp71eb
North Liberty, Ia
We put them on a buddy's jeep that we put a dana 44 up front and a 9" rear. We had to flip the steering linkage so we used these. They get compressed and stay in place on their own and don't need welding.
jbawall
Edgewood, Washington
I bought those a few weeks ago, have not put them in yet but when I do I am going to use lock tite, just in case they want to spin in the hole.
