Bronco_69
I went to and explorer set up and no longer need this. the bracket allows you to put a saginaw pump on the 5.0 mustang serpintine belt system. I will also include the bolts an spacer that i used to fit it up. PUMP IS NOT INCUDED.
http://www.wildhorses4x4.com/product/Delphi_saginaw_pump_bracket/Bronco_HD_Delphi_Steering_Pumps
Delphi/Sag 5.0 Pump Bracket
This bracket originally designed by the famous Lars Pedersen is now available from WH. It's specifically designed for use with your 86-93 5.0 MUSTANG engine and original MUSTANG brackets and our Sag/Delphi pump. This will make quick work of hooking up a heavy duty steering pump to your serpentine belt 5.0.
![2032.jpg](http://www.wildhorses4x4.com/images/large/2032.jpg)
![273_2777_large.jpg](http://www.wildhorses4x4.com/images/uploads/273_2777_large.jpg)
