scorpio007
Just wondering if anyone has done this conversion I bought the advanced adapter kit( which I belive is still available from A.A) from a guy that had a ad in the paper. The toploader overdrive is pretty much the same size as a stock bronco three speed except the output bearing is larger and the case is aluminum. This seemed like a pretty good swap since you would get a larger output bearing, loose some weight from the case, plus you get a lower 1st gear and a 20% overdriven fourth to get you to the stomping grounds. I ended up with the conversion kit and an extra adapter housing from the guy in the paper for around a hundred bucks.(the extra housing will come in handy because it must be machined to fit the larger bearing, and there will be no down time between swaps.) I picked up the trans from a junkyard for fifty bucks, poped the cover and it looked fresh but I will probably clean it up and put a bearing kit in it since it has to come apart any way to install the new mainshaft. I have not yet finished the swap since I need to have the housing machined and buy a new four speed shifter and bearing kit. I was wondering if anyone else has seen, done, or heard anything about this conversion I am curious how it works. Any feedback would be great.
Thank's in advance
SCORPIO
Thank's in advance
SCORPIO
