So Im almost done with the TBP 5.5 Stage 12 left kit. My bronco is uncut at the moment. What size tire should I run? and any rim suggestions? I have a 2 inch body lift installed too. Would 35X12.50 be to big?
you are going to get the following questions.. what are you going to use it for, do you plan on cutting it, what gears are you running, and how much do you want to spend. Also when checking tires, not all 35s are the same size.. example.. bfg all terrain 35 is taller than a mickey mtz 35.. my mtz is closer to 33 than 35 and it is a 35.
all I can say, is that's a whole lotta lift for an uncut Bronco! You could run 35's with half that lift, and trimmed fenders................. the question was already asked, so what do you want to do with it?
The bronco will be used for an everyday driver and the beach on the weekends. Right now the gears are stock and I know I will probably have to change them but ill cross that bridge when I put lockers or posi trac in. As far as the difference in tire sizes between brands I know that too. I had 35 inch pro comp mud terrains on my ram and then went to the dick cepeks same size but the cepeks fit the wheel well so much better. I want to cut it but im not 100% on that and im going to wait till next year when I paint it.
