lift kit opinions
bgs26
Eunice, LA
Currently my '66 is stock. I want to lift it but am not sure what to go with. I want to go high and I would prefer not to use a body lift. WH has a 5.5" kit with 4 shocks or 8 shocks. I read the "shocks" thread a minute ago and it shyed me away from 8 shocks due to the stiffness of the ride. I don't do any heavy offroading, but i do some. It is mostly a sunny day-joyriding bronco. Also, would 35" tires be too big? Suggestions...
DonsBolt
Chestnut Hill, Mass
My sugestion- Since it is mostly a sunny day-joyriding bronco
3.5 inch suspension lift
7 degree wedges
1 inch dody lift
4 bilstien shocks
Gorilla flares- tucked up as high and streatched out ar far as you can
35 tires
Then just enjoy the truck
3.5 inch lift, will give you a lot less headaches with driveline angles, less castor problems, and will clear 35's no problem.
br0nc0xrapt0r
Loves pickles
well the sky is the limit really 35's will fit great with a 5.5 lift and any of the vendors 5.5 kits are good I really favor the wild horses 5.5 though I would use the 8 shock kit but i would just use a softer shock keep in mind you need to lengthen your drive shafts too and if you plan to run 35's you'll want some power steering and power brakes too.
bgs26
bgs26
Eunice, LA
I am in the process of upgrading to disc brakes right now and power steering will probably be the next. I am just trying to figure out what I want so that when it is time to lift I will know what to get. Does WH have softer shocks for this application?
br0nc0xrapt0r
Loves pickles
I would use the wild horses suspension with the new duff 70/30 shocks they have been getting good reviews about their ride quality
