prolinejohn
- Jun 6, 2003
- 15
Talked to BC, Jeffs, Duffs.
Lift kits: Smoother ride
Jeff's and Duff's both use variable rate coils. I have heard you should be aware of front end sag with time with these coils. So which is best linear or variable?
Also Duffs uses a shock that helps reduce the bronco buck. Sounds good does anyone run these shocks?
Do I need to add a drop pitman arm or adjustable track arm?
To cut or not to cut... If I get a 4.5 lift can I put wider tires on my EB? I am very close to saying the hell with it and circumsizing the EB and keeping the foreskins.
Thanks 8)
Thanks 8)
