Lincoln Invertec V160-T Tig/Stick with Pulse
from the Lincoln website:
The Invertec V160-T is a full function DC TIG inverter with excellent arc control. Its built-in gas solenoid and choice of High Frequency or Touch-Start TIG starting make it ideal for a wide variety of DC TIG applications. The V160-T can also weld stick with a variety of popular Lincoln stick electrodes. Its portable rugged design and 115/230V 50/60Hz operation make it ideal for both in shop or field use.
Advantage Lincoln
• Advanced inverter technology delivers superior TIG performance.
• Selectable Touch-StartTM TIG starting or high frequency starting makes it easy to establish an arc under a variety of conditions.
• Built-in pulsing functions give you greater control over thin materials.
• Add TIG capability to your arsenal by using remote power from an engine driven generator.
• Auto-reconnect between 115/230V 50/60Hz input power eliminates operator error.
• Integral gas and power connector for simple torch connections and quick changes between TIG and stick welding.
• Lightweight, rugged package make it easy to take TIG welding capability where it's needed.
• Thermal and voltage overload protection for long life of internal components.
Physical specifications
Weight:24 lbs. (10.8 kgs. )
Dimensions (in) H x W x D : 13 x 8 x 17
New over $1600
Nice Unit, no leads included. Stepped up to a Dynasty DX for AC.
Located in Charleston, SC. Buyer to pay shipping or pick up.
$750
Advantage Lincoln
New over $1600
$750
