Lokar Transmission Dipstick Help
Casey835
This thing is hard to read. When it’s cold, it’s way up the stick. When it’s hot, you can’t figure out where it’s at. I kept track of how much fluid I put in, but still can’t verify correct level. Not using built in cooler on the radiator just the derale 13870 which holds 26oz. of fluid. Stainless braided hose. Have not measured yet for length but I would say it’s less than the factory steel line. I have come to the conclusion an accurate reading can not be taken due to the small diameter of the tube. I believe the tube retains fluid inside of it. I figured I would ask before I take it out and try to replace it with the factory tube.
Sent from my iPad using Tapatalk
