WARDOG
I have to rebuild the rear frame horns which are mangled and poorly repaired by P.O.
If someone has the rear bumper off their Bronco, and their horns aren't mangled / altered, can you post a pic and some measurements.
The measurements I have deduced so far, and if they can be confirmed
Top rail 3" wide
Bottom rail 2.75" wide (or 2 3/4")
Height from top to bottom (outside dimension) 4.375" (or 4 3/8")
Slot further most toward the body 1.375" long (or 1 3/8")
Bolt hole for mounting to bumper 7/16" hole
Hole center location 2.25" (or 2 1/4") to center of slot.
Frame 29.5 (or 29 1/2") outside to outside on top rail
From the center of the mounting hole, how far back does the top and bottom rail stop?
Thanks-
Top rail 3" wide
Thanks-
