Jp76
So I got all the new door innards put in and am shaving the new plastic door handle cup to fit the new door panels, but after the panel is in and the door cup gets snapped into place, the actual door handle tongue needs to go under the "lever" or actuator inside the door. This is spring loaded obviously so that when you pull the handle in, it pops the lever inside the door up, which releases the latch so the door will unlatch and open.
Anyone have a magic way to get the door handle tongue to slide under the inner spring loaded lever? With the panel installed there is no way to manually hold the lever up while sliding the handle tongue in and under. It seem easy but.....
