yellow69
This is most of it I will add more later. need money to start new rock crawler.
james duff extended radius arms needs new frame brakets installed but never used, -$500.00 SOLD
2 JD long travel shocks installed but never used,-$50.00 SOLD
james duff 3.5'' progressive rate coils installed but never used -$100.00
new in the box stage 2 rear shock mounts -$130.00 SOLD
warn chromo shafts W/ctm u joints used -$600.00
new in the box warn chromo shafts -
1- outer $75.00
long inner-$150.00
short inner-$120.00
dana 44 detroit locker 456and up used -$300.00
dana 20 twin sticks used -$ 100.00
west coast broncos rockcrawler steering box used 1 year -$450.00
saginaw power steering pump w/ bracket used -$125.00 SOLD
glove box door w/ clean title -$ 150.00
new dash not in box -$140.00
rear gas tank good shape -$50.00
set of doors great shape no hardware very little surface rust -$300.00 for set
big bearing 9'' complete ratio unknown -$150.00
small bearing 9'' complete ratio unknown -$ 125.00
dana 44 w/ f 150 disk brakes no axle shafts ratio unknown -$300.00
frame no rust shock towers removed and james duff stage 2 shock hoops welded on -$500.00
automatic steering coilum -$50.00
front and rear bushwacker fender flairs new out of box -$150.00
new bronco logo floor mats -$50.00
9'' 33 spline moser axle shafts used -$ 200.00
spool for 9'' 33 spline - 125.00
core support front wheel wells and inner fender aprons all assembled together-$300.00
stock rear springs used $30.00
stock rear small bearing shafts $50.00
stock front shafts complete set no u joints $50.00
dana 30 tie rod and drag link $50.00
1- outer $75.00
long inner-$150.00
short inner-$120.00
