I've started reworking an old M416 military trailer to use as a utility/camping rig behind my Bronco. Hauling firewood and other supplies around the cabin will be its main job for now. In the future - maybe set up more for camping with a tent platform, etc. Who knows?
When I bought the trailer it was in pretty good shape considering its age. Not sure when it was built - 1960's probably? It came with a few dents, some surface rust, and a bit of rust in the frame above one of the spring shackle mounts. It didn't have some of the stuff a restorer would want to see - no data plate, or lunette, military wiring missing. The hand brake setup is complete; not sure if I'll use it.
At this point, the trailer has been disassembled, sandblasted, and primed. The rusty metal in the frame removed, but not patched yet. Purists might cringe, but I cut out the back for a tailgate. The trailer won't float now, but neither does the Bronco. The gate is made from the cut section of the box, flipped around and reinforced with 12 ga square tube. I started out planning to hinge it from the bottom, then switched it to the side to make unloading easier.
If anyone here has experience with these things, please chime in with suggestions, warnings, parts sources, etc.
